wire the LEDs back into the handle area. bore out the handle, and insert the microcontroler, battery, LED pins, and a trigger.
cover up the bore hole where your electronics are stashed.
trigger the muzzle flash for when you pull the trigger. In future projects, I might use a micro phone to trigger the flash. Right now, I'm using a button, and its kind troublesome.
