PCB exposure unit
An exposure box for PCBs made of UV LEDs
A project for creating a tool needed in another project..
Lacking a good exposure unit, I ordered a bag of UV LEDs and started soldering.
So far I'm very happy with the results.
I planed to add a digital timer and intensity controller, but this is not necessary.
Maybe I'll add some paint to the wood for style.
As for now, I plan to add no further Details or logs to this project.
I started with the circuit for the LEDs. Soldering them together in parallel, adding a power transistor (or two for left and right side) was all whats needed.
Transistors were used to open the possibility to add PWM to adjust brightness.
The small wooden box was made out of scrap wood lying around.
PCBs will be placed in a distanve of ca. 50mm to the LEDs. This is a good distance where flow of light is homogenous. Too close and each LED will create a brighter spot, too far and the device will become too big. UV will be absorbed by many materials, I tested some materials and used plastic which did absorb the least amount of light.
Testing was done by shining uv on a sheet of paper and placing materials in the path of light. Good absorbing material results in darker lit paper.
On top of the box is a wooden lid with foamrubber.
I tested several exposure times, 150s to 180s had the best results. As developer I use NaOH dissolved in water.
The next time, I make PCBs, I'll take some photos and upload them.
/update/
I added two photos showing the first two boards made.
The first board was to test several traces and timing. I learned that 150s is a good time for my boards and foil setup.
With the second board something went wrong, there are some bad spots on the ground plane. I plan to improve this in future boards.
I'll also add details about used chemicals.
  • Details on parameters
    Johannes • 09/06/2018 at 19:20 • 0 comments
    I promised to share some details about timing and chemicals.
    So far I used the exposure unit three times. At first with mixed results and the third time with quiet good results. Three is not an adequate sample so future results may vary.
    Safety first
    Whenever you use chemicals be aware of the potential dangers.
    I will not go into detail about all dangers encounters while etching PCBs, but you are generally good to wear personal protection equipment, i.e. safety glasses, gloves and tight clothing.
    If in doubt, ask someone who may have some experience in the field or don't do it.
    Also: Do not store chemicals in bottles used for food or drinks! Pharmacies sell glass bottles for some bucks. Use them!
    Also label every bottle.
    Even if there is only one or two.
    Even if you are the only one using them.
    You know the difference, someone else may not.
    And 'someone else' may be the ambulance who try to rescue you after something (else) has gone wrong.
    (Thankfully I do not speak from experience)
    My current setup for PCB etching is:
    Exposure
    • print out the layout two times on transparent foil, printer setting on 'foil' with a laser printer.
      Wipe both foils clean of any dust or particles.
    • align them and tape them together. This is important as one sheet will not provide enough 'blackness'.
      (I tried toner-density spray on single foils which did not work at all with two different printers.)
    • Without any bright light present remove protection from the PCB. Place layout on PCB and tape both together.
      Place PCB-foil-sandwich in exposure unit and turn on UV light for 2:20 minutes (or 140s).
    Developing
    • remove everything from PCB. Place it in developer.
      Developer is just 10g NaOH dissolved in 1l of distilled water. After some time the traces will be visible.
      I let the board in the developer for about 4 minutes (240s) at 20°C.
    • rinse board with clean water.
      store developer in chemical bottle for reuse.
    Etching
    • Place board in etching solution.
      I use Iron(III)chloride.
    • My trick is to store all chemicals at room temperature. This is easier but FeCl3 works best at higher temperature. Therefore I bought a water bath for the etchant bath, see photo below.
      When i put the board in, the etchant had approximately 40°C, the water bath had 60°C.
      This way I do not need a hot plate or similar.
    • constantly move boar in solution. After 6:30 minutes (390s) all traces were clear.
    • again: rinse board with clean water, store etchant in chemical bottle for reuse.
    While working on the board, I had no time to take photos. So this is the hot bath without etchant.
    After treatment
    When you finished the last step above, the board is (theoretically) ready for soldering.
    Anyway it is easier, if you remove all photoresist and replace it with solder-varnish.
    It is way easier to solder to that, even if it says that the photoresist should be easy to solder - it is not.
    Photoresist is (partially on the right) removed with alcohol or acetone.
    And this is the board with solder-varnish.
View project log
