This shows that the motor shafts are loose, causing inaccuracy. I can rotate the motor shafts several degrees before encountering resistance from the gears. This reduces the accuracy of the machine.
A project log for Pi CNC Plotter Fail
A not-quite-successful attempt at a closed-loop CNC plotter using DC motors and a Raspberry Pi.
