Loose Motor Shafts
A project log for Pi CNC Plotter Fail
A not-quite-successful attempt at a closed-loop CNC plotter using DC motors and a Raspberry Pi.
daniel-james-evansDaniel James Evans • 08/08/2018 at 02:19•0 Comments
This shows that the motor shafts are loose, causing inaccuracy.  I can rotate the motor shafts several degrees before encountering resistance from the gears.  This reduces the accuracy of the machine.
