Quick Update - February 12 2017
A project log for Aquila 2.0 - MQTT-SN based IoT Platform
MQTT for low power devices
rodmgRodmg • 02/13/2017 at 01:35•0 Comments
aquila-gateway - Released version 0.6.0
- Implemented removing devices from the monitor API.
- Changed Monitor API: All "*/get" command topics are now "*/req" for consistency with responses ("*/res"). Old API is still supported but deprecated.
- Minor bug fix: incorrect buffer function usage in Serial and TCP Transports.
The first change is useful when managing devices from a custom app. Usage:
Removing a device:
  1. subscribe to gw/devices/remove/res
  2. publish to gw/devices/remove/req a json with the address or id of the device to delete. Example: { "address": 23 } or { "id": 23 }.
  3. You should get a JSON response via the subscription to gw/devices/remove/res: { "success": true } (or false).
More info in the docs: https://github.com/Rodmg/aquila-mqtt-sn-gateway/blob/master/doc/index.md
