The DPS3012 is the main power control unit. Since It can handle input voltage up to 40VDC I use 120-240VAC to 36VDC switching power converter as the supply.
Although the DPS3012 can handle up to 12A of output current, the AC/DC converter I bought can only handle 5A. That limits the device from reaching its full capacity.
Anuradha Gunawardhana
Mukesh Sankhla
Is there an STL for this?
