How does it blink?
A project log for PurpleSnowy
PurpleSnowy is a small badge. You can pin it on your clothes or backpack. You can add it to your key chain. It is cute and shiny.
nwmakernwmaker • 08/29/2018 at 20:40•0 Comments
The version 2 of snowy owl uses a dual inverter NL27WZ04 made by OnSemiconductor. Both gates are in use. So it is still ring oscillator, but not the usual hex inverters.
