I thought this would be worth publishing a log about.
While preforming a load test I found that the flexspline will start to rachet if too much reverse torque is applied. I find this interesting, I was under the impression that the first mode of failure with this version of the flexspline would be the teeth shearing off.
I'll be working on a fix for this issue over the next few days. A few ideas in mind have are:
- Use a less ductile TPU (I have various types on hand)
- Change the tooth profile
- Print the teeth and one boundary layer (in Cura slicer "wall line") in nylon and leave the structure of the flexspline printed in TPU
I've also been given a suggestion by Gabrael Levine, the designer of OpenTorque Actuator, to alter the wave generator geometry to keep a preload on the flexspline. I shall see what works best and include it in the next Open HD revision.
If helps, I'm agree in using the most rigid TPU, the printed tooth profile should match exactly the belt tooth, also a preload would help.
But for me, also the key is to ensure that the belt is oil / grease resistant.
