Hackaday.io Hackaday.io
Sign up Log in
DIY Nano Drone
This project is a answer to question "How a DIY nano drone look,feel and fly made out of MDF ,3D printed parts?".
ramkumar-rRAMKUMAR R
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.9k views
0 comments
1.8k followers
  • Description
  • Details
  • Files 0
  • Components 5
    • View all
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
1.9k
0
1.8k
22
Team (1)
  • ramkumar-rRAMKUMAR R
Join this project's team
hardware
completed project
drone
This project was created on 08/11/2018 and last updated 3 years ago.
Description
Looked around some nano drones, realized the frames of the nano are mostly 3D printed as single piece.Some them are DIY .But that gave curiosity what if wood is used for building a nano drone ,which lead to what I did. I did laser cut MDF and 3D printed some parts,gave color. Finally put it together,flew it with #fun.
Details
This Project is done on modular drone "PlutoX" from Drona Aviation.To check click!.
Components
  • 4 × 7 mm brushed motor
  • 1 × primus v3r board https://www.dronaaviation.com/product/primus-v3r/
  • 4 × 55 mm propellers
  • 1 × 380 mah battery
  • 4 × prop guard
Log In/Sign up to comment
Sign up with Github
OR
Low cost 3D printer that uses drawer runners for linear bearings with no laser cut or 3D printed parts. Large print volume and good quality
Project Owner Contributor
jonathan-irwinJonathan Irwin
PLA Plate is to recycle 3D print waste and used plastic parts into a 1/8in PLA plate for laser cutting
PLA Plate -Recycled Failed 3D Prints-
yusuke-tanakaYusuke Tanaka
This model is currently using laser-cut parts, 3D-printed parts and off-the-shelf parts.
Parametric Electronics Enclosure
twisted-pair-in-my-hairTwisted Pair in my Hair
3d Printing and Fiberglassing a 1:1 replica Bugatti Chiron built on a bmw 330ci.
3D Printed Replica Bugatti Chiron
peter-buckleyPeter Buckley
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "DIY Nano Drone", please tell us the reason.
Send message
Remove Member
