Data Types
A project log for TRCM
Attempt to reinvent the wheel of HDL
shaosSHAOS 08/12/2018 at 05:090 Comments
I started with a few template classes:
Wire<N> - generic wires (base class for everything else)
Uint<N> - unsigned N-bit integer
Sint<N> - signed N-bit integer
Tint<N> - balanced ternary N-trit integer
Also there is class Signal that is the same thing as Wire<1> (a single wire)
Every wire may be in one of the states listed below:
NC - not connected (internally represented by character 'Z')
TRUE - connected to positive power line (internally represented by character 'P')
FALSE - connected to negative power line (internally represented by character 'N')
MAYBE - intermediate state to simulate ternary logic (internally represented by character 'O')
PULLUP - weak pull-up to positive (character '1')
PULLDOWN - weak pull-down to negative (character '0')
INVALID - invalid state that prevents simulated circuit to work properly (character '?')
In future I want to support fixed point and floating point numbers (but not right now).
Sample code to test basic types:
#include "TRCMath.hpp"
using namespace std;
using namespace TRC;
int main()
  Wire<5> a;
  Wire<32> b;
  Wire<1> signal,out;
  Signal signal2;
  Uint<32> u;
  Sint<32> s;
  s[0] = TRUE;
  b[31] = FALSE;
  s = b&&u;
  signal = MAYBE;
  signal2 = TRUE;
  out = signal & signal2;
  cout << "signal=" << signal << endl;
  cout << "signal2=" << signal2 << endl;
  cout << "out=" << out << endl;
  cout << "a=" << a << endl;
  cout << "b=" << b << endl;
  cout << "u=" << u << endl;
  cout << "s=" << s << endl;
Objects Wire<N> will support only logical operations and all integer simulated types will support also arithmetic.  Above you can see how operator && (bitwise AND) was applied to two Wire<32> objects and operator & (logical AND) was applied to two Signal objects.
Source code is available under GPLv3 on GitLab (it is still work in progress):
https://gitlab.com/ternary/trcm/blob/master/TRCMath.hpp
Now I'm thinking about the way to support reliable multiple state machine simulation (with ability to run simulation concurrently to occupy all available cores of host PC).
Rich text editor
