In order to make independent blocks that communicate with each other user should create derived class from class Entity for every such block:
class Unit1 : public Entity
protected:
// indecies:
int i0,i1,i2;
// inputs:
Wire<8> net;
Uint<8> bus;
// outputs:
Signal sig;
public:
Unit1()
// attach your entity to global wires
i0 = at("bus",8,PULLUP);
i1 = at("network",8);
i2 = at("single");
void step()
// read your inputs
for(int i=0;i<8;i++)
bus[i] = io(i0+i).read();
net[i] = io(i1+i).read();
// do something
sig[0] = TRUE;
// apply your outputs
io(i0) << sig[0];
io(i0+1) << sig[0];
io(i2) << sig[0];
// additional trigger logic
if(posedge(i1+5))
// here we can have logic that should work on positive edge of network[5]
In future method step() of each user entity (that executes 1 step of simulation) will run in a separate thread...
Source code is available on GitLab: https://gitlab.com/ternary/trcm
