This microcontroller-based system simplifies control electronics for optical fiber-based fluorescence measurements in neuroscience.
x-zip-compressed - 3.81 kB - 04/26/2019 at 20:13
x-zip-compressed - 3.72 MB - 08/21/2018 at 20:55
octet-stream - 43.00 kB - 08/21/2018 at 20:54
Standard Tesselated Geometry - 52.04 kB - 08/12/2018 at 22:02
Standard Tesselated Geometry - 1.07 MB - 08/12/2018 at 22:02
View all 7 files
View all 19 components
Download following files and store on your computer:
1) PhotBox_v1d_sch1_2018-07-24.zip
2) FibPhotBox_v3_lid.stl
3) FibPhotBox_v3_box.stl
4) fibPhotBox6_LPC1768.bin
Navigate to:
https://www.seeedstudio.com/fusion_pcb.htmlClick "Add Gerber Files"
Navigate to and select "PhotBox_v1d_sch1_2018-07-24.zip"Click "OK"
Make sure PCB Dimensions are 100mm x 160mm
Select desired color
All other default options should be OK
Order all other commercially available components off of parts list from Digikey,
McMaster-Carr and National Instruments
View all 13 instructions
Salvador Flores
johnfoster
Charles D Stutzman
Rupert Young
Yes, delete it Cancel
You are about to report the project "PhotometryBox", please tell us the reason.
