Started some preliminary research on my design.
- Found a nice November sky graphic to use as a reference.
- Pulled the graphic into adobe illustrator to scale the design.
- Looked into scaling the size.
- Likely I will use my 3D printer to print a frame for the PCB
- Printer is only capable of 200mm x200mm max.
- Not actually sure if it can handle that size.
- Researched some reverse mount LEDs, for a clean PCB top side.
- White not available in a nice dome top.
- Go with square?
- Use an alternative method.
