Today we're showcasing 12,000 mm / minute of sweet FOSS pick and place automation.
We've also upped the complexity in this run by pick and placing components for a circular board. And we're placing 4 different components in 2 different rotations.
And we're doing 2 boards at once!
Why all of that at once? Because why not that's why!
All I'm saying is this isn't last week's pick and place!
Final Score: 9 / 12 Pick and Places successful.
Regarding y-axis I hear you. I've got an old Mendel of my own sitting around gathering dust. The issue is really that a pick and place for moving y beds would have to be a very different design.
It would be cool if someone took our work and made a fork that focused on Mendel-type printer compatibility but the focus of the RetroPopulator project for now is on getting the pick and place functionality working.
Regarding a secondary control board, I do wonder if ultimately we may end up adding one for some super-high-end version of the design (maybe even going as far as to design a full-fledged p+p-specific Populator cartesian bot at some distant point in the future). It's certainly a possibility.
The second board would mean a significant software change. I'd need to write a Tegh* driver that can control two arduinos. And we'd need some way to sync their movements.. that would be difficult since GCodes are buffered on RepRap firmwares so you don't get any notification of the completion of a movement. Then again, we might even just be able to use timing to sync them. It doesn't need to be super precise if it's just a part rotation during travel. Weird. Definitely possible though..
Thanks for the idea and taking the time to check out the project!
*Tegh: my Wifi RepRap control software, it's a cross between Pronsole and OctoPrint.. I've got a lot of documenting to do on the software side :)
