As S-BUG is working reasonably now, The next step is to move on to SD-Card access. @Dolo is generous enough to allow his SD-Card code to be used as a framework for the 6809v2 project. Make sure you check his projects out. Thanks Dolo!
A project log for 6809 v2
A 6809-based project- a simple board that's intended for 6809 OS'es that run in 64k of memory and work with a serial console
Good luck David and you are welcome! I will be interested to see how the 6502 code translates to 6809, I expect it will be a little more efficient. Cheers, Dolo
