It is kind of sad for what pass for speaker in sub $100 LCD TV these days when I can hack a better one from mostly recycled junk I have. It is not much to look at as most of the parts are already paid for one way or the other. i.e. recycled
Ironically the speakers I used are from my old CRT TV back in the days before form over function. I cut up one old FedEx shipping box as they are a bit more sturdy than regular cardboard boxes. If I only had cans of epoxy and fiber glass cloth around, I would try to build-up a more rigid shell.
I use old ball point pen to create creases lines for folding without damaging the cardboard. Just to humor myself, I stuff the box reusing some of those foam sheet from usual chinese orders. A few self tapping screws are used to loosely mount the speakers.
A $0.30 PAM8403 "3W" class D amplifier is used to power these speakers. It runs off my TV USB port.
I have modded the amplifier by reducing the gain with the values from the datasheet as they weren't built correctly. I think they were using 10K.
![](https://cdn.hackaday.io/images/9095611640193248729.png)
I also added a 5V power supply supervisor circuit to pull the /Mute to reduce the popping as TV powers on/off its USB. I needed a few hundred millseconds on mine.
As usual, read the datasheet especially for cheap questionably modules .
