This list is made with only mentioning how it handles digital logic and interrupts
DRV8825: https://www.pololu.com/product/2133
Pin | Function | Status |
EN | Logic high to disable device output and indexer | Input, Internal pulldown |
M0 | Set step mode | Input, Internal pulldown |
M1 | Set step mode | Input, Internal pulldown |
M2 | Set step mode | Input, Internal pulldown |
RST | Logic low to reset indexer and disable output | Input, Internal pulldown |
SLP | Logic low to enter low-power sleep | Input, Internal pulldown |
STP | Rising edge move stepper one step | Input, Internal pulldown |
DIR | Logic level sets direction | Input, Internal pulldown |
FLT | Logic low when in fault condition | Output, open-drain, pullup to sleep pin |
Limit switch:
1 | Endstop, need interrupt pin preferably | Output, Normaly Open |
This means that we need 8 outputs that doesn't have fixed pullups and can handle boot with pulldowns on the pins. And 2 interrupt inputs with at least one that has a pullup.
As seen in the list below this means that D3 and D4 need to be inputs and one of the serial lines as output.
NodeMCU v1.0 Amica ESP-12E:
Pin | Function | Status | Can be used as |
D0 | GPIO16 | Not usable with deepsleep, Hi-Z DIO, no interrupt | Output |
D1 | GPIO5 | Hi-Z DIO | Output, Input, Interrupt |
D2 | GPIO4 | Hi-Z DIO | Output, Input, Interrupt |
D3 | GPIO0 | No Hi-Z DIO (prefere pullup) | Input, Interrupt |
D4 | GPIO2 | Don’t connect to ground at boot time (prefere pullup) | Input, Interrupt |
D5 | GPIO14 | Hi-Z DIO | Output, Input, Interrupt |
D6 | GPIO12 | Hi-Z DIO | Output, Input, Interrupt |
D7 | GPIO13 | Hi-Z DIO | Output, Input, Interrupt |
D8 | GPIO15 | Can't have pullup (only pulldown DIO) | Output |
RX | GPIO3 | Not usable during Serial transmission | Output, Input, Interrupt (if serial not used) |
TX | GPIO1 | Not usable during Serial transmission, Don’t connect to ground at boot time | Output, Input, Interrupt (if serial not used) |
A0 | ADC0 | Analog | Not usable as DIO |
SD3 | GPIO10 | Might be connected to flashmemory!!! | Not usable |
SD2 | GPIO9 | Might be connected to flashmemory!!! | Not usable |
SD1 | MOSI | Unknown | |
CMD | CS | Unknown | |
SDO | MISO | Unknown | |
CLK | SCLK | Unknown | |
EN | Enable | DigitalWrite/Read not possible | Not usable |
RST | Reset | DigitalWrite/Read not possible | Not usable |
