Some basic definitions and a single phase test. PoC.
/* 3 half bridges made of complementary FETs, all gates are driven by MCU
* high sides are off when corresponding MCU pins are high
* low sides are off when corresponding MCU pins are low
* 3 phase motor connected to half bridge outputs
* these outputs are also connected to MCU analog pins to provide voltage feedback
#define PAH PB7 //phase A high side
#define PAL PB14 //phase A low side
#define PBH PB6 //phase B high side
#define PBL PB13 //phase B low side
#define PCH PB5 //phase C high side
#define PCL PB12 //phase C low side
#define PAF PA0 //phase A feedback
#define PBF PA1 //phase B feedback
#define PCF PA2 //phase C feedback
int fba, fbb, fbc;
void setup() {
pinMode(PAH, OUTPUT);
pinMode(PAL, OUTPUT);
pinMode(PBH, OUTPUT);
pinMode(PBL, OUTPUT);
pinMode(PCH, OUTPUT);
pinMode(PCL, OUTPUT);
pinMode(PAF, INPUT_ANALOG);
pinMode(PBF, INPUT_ANALOG);
pinMode(PCF, INPUT_ANALOG);
//neutral, off state:
digitalWrite(PAH, HIGH);
digitalWrite(PAL, LOW);
digitalWrite(PBH, HIGH);
digitalWrite(PBL, LOW);
digitalWrite(PCH, HIGH);
digitalWrite(PCL, LOW);
void loop() {
digitalWrite(PAL, HIGH); //drive phase A low (turn on low side transistor)
digitalWrite(PBH, LOW); //drive phase B high (turn on high side transistor)
fba = analogRead(PCF); //read feedback voltage
//delay(1);
digitalWrite(PBH, HIGH); //drive phase B low (turn off high side transistor)
delay(10);
Serial.println(fba);
