Recently IBM bought Red Hat for $33 Billions mainly for its Openshift Container Platform. I created this demo using AMQ , Kafka, Fuse Online running on Openshift. Max's movement is sent using MQTT and saved in a Kafka topic and then taken from the Kafka topic and saved in a file on a FTP site using Fuse Online integration. The file is then used as the source to playback the movements on Max using a small Java program.
Enjoy ;-)
