"Look ma, no wires!"
The battery holders finally arrived. I couldn't resist and soldered them right away.
Some solder is needed on the ground pad to contact properly with the battery.
Finally complete!
Just a quick check to see if everything works:
And now we wait for the case and the final assembly!
