Battery usage quick update and Redox Wireless release.
Here's the latest measurements. The batteries seems to have stabilized around these values, I might need to find a multimeter with higher resolution to better check the voltage.
| Left hand voltage | Right hand voltage | |
| 30/09/2018 | 2.98 | 3.04 |
| 06/10/2018 | 2.98 | 2.99 |
| 13/10/2018 | 2.96 | 2.97 |
| 20/10/2018 | 2.97 | 2.98 |
I now feel sufficiently confident with the power consumption to release the PCB files as open source on the Redox project repository. Here you'll find:
- The transmitters gerber files
- The receiver gerber files
- The KiCad project files
- The KiCad footprint library files I've used
I'm also merging the Redox firmware sources into the QMK firmware project. I'll still monitor the battery usage in the following weeks and report regularly.
See ya next time!
Mattia Dal Ben
