In short I didn't do much work to make this happen it was the creator Pyxel who in his/her infinite wisdom decided to replace glfw as a dependency and decided to make sdl2 the base framework. The main trick to get half decent frame rate was that I killed the entire desktop manager beforehand.
![](https://cdn.hackaday.io/images/original/8441341564548582503.gif)
