Such small boards require some iteration in design:
- Lay the components,
- Choose the pins to use for each function
- Draw some straight lines between pins that shall be interconnected
- Connect pins schematic
- Route the board
- Repeat all steps as necessary until routing is finished (and you're happy with it)
