The function scanControllers( ) can detect if the controller is a 3 button or a 6 button or even a Master System SMS controller and return a 16 bit value with the following format:
// 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 0
// 0 0 0 0 MD X Y Z ST A C B RG LF DW UP
I have some 6 button controllers but none with 3 button neither a SMS controller, but if the pin SELECT is tied to a fixed logic state then the controller will change its behaviour, being detected as:
// SELECT = HIGH: SMS controller
// 0 0 0 0 0 0 0 0 0 0 C B 1 1 DW UP
// SELECT = LOW : 3 Button controller
// 0 0 0 0 0 0 0 0 0 0 ST A 1 1 DW UP
Notice that 3 button controller will show LEFT an RIGHT both pressed and START and A instead of B and C, nevertheless the controller is being detected as a 3 button.
