Parametrization in action
A project log for qlbrd (cool board)
QLBRD is a ball shaped input device that attempts to solve issues related to ergonomy, usability and comfort of use of remote controllers.
dhgdhg 09/03/2018 at 20:140 Comments
As promised I publish some parametrization setup in Blender (that uses great Sverchok addon) intended to provide an easy tool to make QLBRD clones. It has lots of settings that can be manipulated.
It took me some time to publish it as the worst part of any code is documentation. But finally I found needed power to both write some explanation in code and make a small presentational render you see below (however was too lazy to add sound).
A more detailed description will put in instructions. A file with node setup lands in project files.
Rich text editor
