In the hunt for heaters to use in the heated build chamber i ran across an old toaster which seems to fit the bill fine. At about 400w apiece they should be able to warm the heated build chamber.
A project log for Jadoo's All in one
An all in one DIY lab in a box 3d printer, laser cutter Heated Chamber and Exhaust removing enclosure.
