Glove buttons positioning: The button positioning on the working prototype was according the size and shape of it and how much I’ll have to move my thumb to press them. A standard can be set for final models hoping that smaller buttons can be used.
Buttons were not glued directly to the glove, to avoid damages when soldering, also because I used instant glue which can crystalize the glove and make it breakable easily.
The length of the wires coming from the buttons should be set at a point close to the wrist, then soldered to the cables coming from the keyboard PCB.
