I only made 2 mistakes on this one, both involve the 5v rail. One mistake involves drilling a via out, the other is cutting a trace and soldering a jumper.
The firmware for the STM32 works on the first try, which is rare. Now the display is handled by the micro instead of sbc.
Big ups to @Sunshine_Jones for the boot screen quote from embedded.fm.
Currently working on bringing the linux version up from 4.13 to 4.18. Playing with -mtune gcc options in buildroot.
Learned about `ldd -v` and `patchelf`, so I'm creating a small script to help non-developers bring their favorite binaries over to this. I have this feature working with orca, which you can find here: https://github.com/hundredrabbits/Orca-c . It basically finds all shared library dependencies, copies them over, tweaks the search path for that binary, tars it, and it generates a shell script for the LD_LIBRARY_PATH update when you try to run the binary.
This week will be dedicated to getting the linux groundwork complete so I can work on full feature compatibility within puredata. I also ditched python and the curses module for the screen. Its all OSC messages over the serial port now.
