Started work on the initial idea for the blocks.
Thrashing out how the software should work.
I decided on using a very small MCU for the project as I need to keep the power, cost and PCB real-estate overheads low. The idea is to use an Microchip ATTiny10. Which is small and low cost with low power overheads.
