Little Problems
A project log for Smart Small Greenhouse
... Keeping his inside conditions to take care of plants.
juan-sandubeteJuan Sandubete • 09/17/2014 at 12:03•0 Comments
Well, I realised that I have two problems...
The first, the motor which has to raise the skin is not so strong as I want. Then, I thought two ways to solve the problem:
- Change the motor to another stronger (but I hasn't that and it supposes more energy to do the motor works).
- Change the system to raise the skin (like little pulleys or something like that over the greenhouse)
I accept recommendations !
The second problem is that, for the first video (that has been removed and I think I have to do it again...) I did the connections with a protoboard only, not soldered. Now, of course, I want to make it in a PCB, but I have not those materials (sheet, acids, all that) and, because of this, I will take more time for doing it while I get all necessary things.
I'm sorry for the delay, I have not even started with the degree and I'm not very experienced making machines.
Thanks for reading !
