For hardcore folks there is a hardware programming mode. One can add DIP 16 bit switches to manually enter data into the memory-card. Any ideas or thoughts about this would be interesting.
A project log for Memory-Card made of AMD's CMOS UV-EPROMs
The idea is to help you make use of the old and trusted hardware for memory hungry projects instead of wasting money on fancy stuff.
