Iteration
A project log for P1 - Lego compatible drag feeder
Modular Pick and Place drag feeder you build to suit, on a Lego sheet.
masterofnullMasterOfNull 09/13/2018 at 22:060 Comments
I have a 3D printer again, so I printed some of these out.
The pins were too small between the base and the top bit to print reliably.  I've made them bigger.
I also corrected the math for positioning the pick and feed holes so it scales correctly for different tape widths.
I'm printing them out again before I post the updated code, but the C1 end effector still has a couple hours to go for it's latest revision.
Rich text editor
