There is an open-source compiler called GALasm at Github.
GALasm
Pros:
- Open source
- Runs on Linux natively
Cons:
- Limited to a few GAL chips
- Needs Opal files to be edited to a new format
- Pin lists must include NC pin names
- Pin names limited to 8 characters
Opal
Pros:
- I can run it on MSDOS and a Linux DOS emulator
- Supports many GAL and PAL chips
- Written by a chip manufacturer
- Thoroughly tested by industry
I shall be sticking to Opal, because I can run it on both machines
Keith
