One can never test enough - literally.
The STM8 eForth test automation in Travis-CI tests the background task, but it doesn't test its cadence. Maybe that can be done, and maybe it would have been worth doing that. I could have done a manual test - just flashing a W1209 would have shown a flickering LED display - but I didn't. You live and learn...
@Andrew Clapp first discovered that something was wrong. I then identified the cause: a classic "don't use LDW for timers"-error. I first thought that it only hits STM8L devices but also STM8S, this means the whole release was affected. A quick bug-fix release therefore is the best option.
@Eelco the praise came too soon - please check if the 2.2.25 release still solves your problem!
On the plus side: I added INTRX for buffered console RX to the library. Compilation to RAM at 115200 baud really feels much faster than at 9600 baud!
You are welcome.
I found another minor issue: I think that EEPROMBASE in forth.asm should be moved to target.inc (and set to 0x1000 for STM8L*). EEPROMEND in target.inc of STM8L* should be set to 0x10FF. Although these constants are not used in the core it might lead to confusions.
You're right, they should be configurable and exposed in /target. I though about doing just that before the release but then decided against it because I didn't want to edit so many target.inc files before the release. I will make that change in the 2.2.26 :-)
@Eelco done: https://github.com/TG9541/stm8ef/issues?q=is%3Aissue+is%3Aclosed
#i EESTART Uploading: ./target/EESTART
$1000 CONSTANT EESTART ok
Closing: ./target/EESTART ok
Bedankt!
Hi Thomas
I just checked: my charge controller application works with both release 2.2.25 and 2.2.24.
It uses a background task but I changed the time base to 0.36 sec. :
7 TIM2_PSCR C! $AFC8 TIM2_ARRH 2C!
so maybe that is why it worked all the same.
I used to change the baud rate in the forth.asm file, but now it can be done in the inc/defconf.inc file, right? But probably INTRX is more practical.
Thanks for the feedback!
Yes, changing the baud rate can (maybe should) be done in globconf.inc. Using the new exported code parameters, as INTRX does, is a good option if changing the baud rate in the application is desired.
