Thanks to OpenOCD and GDB: STM8L101 now works!
Besides resolving the problem of actually flashing this chip (I never managed to do that with STM8FLASH), and finding the right configuration for OpenOCD (see the previous log entry), setting the SP to a valid address for this chip (1.5K RAM!) resulted in a prompt (GDB again proved helpfull).
For now I'm using the following target.inc:
; STM8L101F3 device and memory layout configuration
TARGET = STM8L051F3 ; let's use this for now - to be fixed later
RAMEND = 0x05FF ; "RAMEND" system (return) stack, growing down
EEPROMBASE = 0x1000 ; "EESTART" EEPROM start address (not really)
EEPROMEND = 0x10FF ; "EEEND" 256 bytes EEPROM (see datasheet...)
FLASHEND = 0x9FFF ; "FLASHEND" 8K devices
FORTHRAM = 0x0030 ; Start of RAM controlled by Forth
UPPLOC = 0x0060 ; UPP (user/system area) location for 1K RAM
CTOPLOC = 0x0080 ; CTOP (user dictionary) location for 1K RAM
SPPLOC = 0x0550 ; SPP (data stack top), TIB start
RPPLOC = RAMEND ; RPP (return stack top)
Here is a initialization code snippet of boardcore.inc that enables TX push-pull:
; BOARDINIT ( -- )
; Init board GPIO (except COM ports)
BOARDINIT:
; Board I/O initialization: enable USART TX->PC3, RX->PC2
MOV CLK_PCKENR1,#0x21
BSET PC_DDR,#3
BSET PC_CR1,#3
RET
There are some points that need to be worked on (e.g. BG, EEPROM, RAM layout) and many things are untested. All the important bits works, e.g. writing to NVM!
This means that I'll have to review many docs that state that it's unlikely that STM8 eForth will ever support this chip.
