Forth to Flash
A project log for eForth for cheap STM8S gadgets
Turn cheap modules from AliExpress into interactive development kits!
thomasThomas 10/29/2016 at 11:160 Comments
As outlined in the previous log entry, compiling Forth to NVM requires some changes. I had to refactor some code (e.g. the way PAD works in a background task) but now I can compile words to Flash, and use them together with a volatile vocabulary in RAM.
Did I mention that this is a great way to do automated tests on different integration levels from unit tests to SW-HW-integration?
Now I did.
By the way, I just pushed the changes to GitHub.
