As outlined in the previous log entry, compiling Forth to NVM requires some changes. I had to refactor some code (e.g. the way PAD works in a background task) but now I can compile words to Flash, and use them together with a volatile vocabulary in RAM.
Did I mention that this is a great way to do automated tests on different integration levels from unit tests to SW-HW-integration?
Now I did.
By the way, I just pushed the changes to GitHub.
