I toyed a bit with the "LM2596 with voltmeter" module. In case you're interested in the details of the voltmeter part, here is how the STM8 pins are connected:
Pin STM8 Connected to (LED pin # in brackets)
1 PD4 F (10)
2 PD5 A (11), LED "in"
3 PD6 V1 (12) cathode digit 1
4 NRST (6), manually wired
5 PA1 E (1)
6 PA2 D (2)
7 VSS GND
8 Vcap Cap
9 VDD +3.15V (LM317)
10 PA3 DP (3)
11 PB5 (nc)
12 PB4 (LM2596 pin5 "/enable", pull-up, manually wired)
13 PC3 LED MPX, key "out"
14 PC4 C (4)
15 PC5 B (7), LED "out"
16 PC6 V3 (8) cathode digit 3
17 PC7 V2 (9) cathode digit 2
18 PD1 G (5), key "in", SWIM
19 PD2 Ain "out"
20 PD3 Ain "in"
Here are details about the LED MPX and the key scan:
LED MPX: rate 20ms
- Duty PC6, PC7, PD7 (digit 1 .. 3): 2.285ms (low)
- Duty PC3 MPX LED in/out: 0.844ms (low)
Key scan after LED MPX active (low):
- 4µs PD1 G high (input, low while key "in" is pressed))
- 1µs PC3 MPX high (input, low while key "out" is pressed)
Key scan while the display is off:
- scan rate 8.165ms
- 4µs PD1 G high (input, low while key "in" pressed)
- All LEDs are dark and MPX is off while any key is pressed
Please note that the duty cycle of each 7-S LED digit is about 11%, and just 4% percent for the LEDs "in" and "out". The reason is simple: there are no current limiting resistors, and the supply voltage of 3.15V is much too high for a red LED. Part of why the LEDs don't overheat is that the STM8S output stages limit the current, and that's also visible at GPIOs that are in not connected. In awareness of that I ran the MPX with a duty cycle of 25%.
The LEDs aren't that much brighter than with the previous firmware:
The board clearly has some potential, but I'll wait until I know the
details of some other variants before I add any code to the master
repository.
