Issue #27 on GitHub discusses use case, requirement, and solutions:
- Introduce assembler features
- Extend the compiler (tail call optimization)
- Introduce the ALIAS word class
- Mix STC with DTC (using ALIAS words), or ITC (using a Inner Interpreter)
- Malleable dictionaries
- and more
If Java is like coffee to make you type faster then Forth is like LSD which makes you see solutions in the fractal complexity of the universe!
EDIT: RigTig used the alias method to create a lean-and-mean configuration for the W1209 board: it fits in about 3.5KiB code, almost 2KiB less than the normal W1209 variant, LED display code included!
Check it out here.
