M. Mahlow reported what appears to be an old STM8 eForth bug:
1 PICK equals DUP
The correct behavior is:
0 PICK equals DUP
1 PICK equals OVER
Note: the correction is a braking change!
Fact is that in STM8 eForth PICK never worked as it should. The core uses PICK only once (in .S), and there 1+ was applied just before calling PICK (with a different indentation). Of course, PICK could have been fixed instead of "fixing" a routine using it.
In STM8 eForth 3 library functions had to be fixed ( @inter, 2OVER, and DSQRT). Hopefully not too much user code depends on the buggy PICK behavior.
