Looks like I lied. While working on it, I realized that I couldn't Control+C anything because I hadn't implemented the Control Key, so I quickly added a Control Lock Key so you push that, then the letter you want. Got RetroPie installed, but it doesn't want to run from the Pi Desktop, so I will have to look into that. Not a high priority though as it currently does all of the basics that I want.
