PCBs Arrive & Lasering an Enclosure
A project log for Peppermint
A flag-themed blinky countdown memento for time spent apart, with capacitive touch switch.
benjamin-broceBenjamin Broce 10/07/2018 at 01:220 Comments
PCBs arrived from OSHPark a bit earlier than expected (past the challenge deadline, but that's my own doing)! Just a bit of cleanup, and they'll be ready for soldering (once the DigiKey order arrives).
PCB dwarved by it's prototype :)
I decided to learn a bit of Inkscape to design my SVGs for laser-cutting an enclosure. I used the tutorials by ATX Hackerspace and Eric Bredder. My idea was to stack 4 layers of 1/8" MDF with a top cover of 2mm Acrylic, which could then be engraved. I accomplished this by exporting an SVG board representation from KiCad, importing it into a layer in Inkscape, and designing each piece of the enclosure in a separate layer, to process and gather into each actual layer of material. The master file (all layers overlayed) ended up like this:
I decided to do a negative raster on the top acrylic layer, such that everywhere my text and images weren't were engraved, to allow more diffuse area for the LEDs to shine through:
The image is of the Angel Moroni (an important symbol of missionary work in my church), and the text is a translation of "God Be with You 'Til We Meet Again".
The lasering turned out really well!
