I used the coupling strategy once so far. It worked quite well. The first time through I hand coded everything. For the second time through, I'm making a code generator. At the time of writing, the generator is mostly done. The generator outputs a python module to be integrated in a cocotb test bench and a modelica model. I'll be trying to use it soon.
Although it's almost certainly full of bugs, I have the generator up on GitHub: https://github.com/adamLange/hdlModelicaInterfaceGen
