I used ThingSpeak's web servers to upload the sensor's readings over the Internet, since I needed values every minute or so and not every second, so I easily got to use ThingSpeak for free. Here are some sample readings I got:
I'm reading the parameters such as, voltages, LDR value, Humidity and Temperature and can easily be plotted using ThingSpeak.
Anas Raza Khan
