The manufacturing programming/test fixture is a fair bit of code running on a PJRC Teensy 3.5. Over the last few weeks I have worked on various subsystems
- Arduino library for the test fixture hardware itself
- Silicon Labs C2 programmer for the Teensy
- Hex File utilities
- Simple display support for the cap touch control LCD screen
- A custom test firmware to first program on the Charger's SI EFM8 micro-controller to allow detailed testing and calibration
And finally I have gotten them all stitched together along with a test sequencer and am writing test code. It's tedious because for every test I have to figure out what's right and what the limits for valid measurements may be. But I see the light at the end of the tunnel now.
