Hackaday.io Hackaday.io
Sign up Log in
RTL-SDR to acquire data from GOES-16 satellite
Documenting my process of getting data GOES-16
joshuavaderjoshua.vader
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.4k views
0 comments
8 followers
  • Description
  • Details
  • Files 0
  • Components 6
    • View all
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
1.4k
0
8
3
Team (1)
  • joshuavaderjoshua.vader
Join this project's team
ongoing project
Related lists
Radio
Antennas, HAM, raspi radios, etc.
This project was created on 09/20/2018 and last updated 8 years ago.
Description
Inspired from watching many of The Thought Emporiums' youtube videos: https://www.youtube.com/channel/UCV5vCi3jPJdURZwAOO_FNfQ
Components
  • 1 × https://www.amazon.com/TP-Link-Directional-Parabolic-Connector-TL-ANT2424B/dp/B003CFATOW/ Grid Antenna
  • 1 × https://www.amazon.com/TRENDnet-Reverse-Weatherproof-Connector-TEW-L208/dp/B000FICJ8S/ N-Connector to SMA cable - 8M
  • 1 × https://www.amazon.com/Pyle-Universal-Speaker-Stand-Holder/dp/B000E0PPG0/ Generic tripod for antenna
  • 1 × https://www.amazon.com/Nooelec-SAWbird-GOES-Barebones-Applications/dp/B07GBFNV1H/ combo LNA / Saw Filter
  • 1 × https://www.homedepot.com/p/Blaster-9-3-oz-Advanced-Dry-Lube-with-Teflon-16-TDL/202532762 Can of spray teflon lubricant for tripod moving components
View all 6 components
Project Logs
Collapse
  • Saw filler / LNA doesn't power up
    joshua.vader • 09/23/2018 at 04:36 • 0 comments
    On Discord I received some great help with troubleshooting my setup from Pietern ( developer of GOES Tools) and other members to determine my LNA was not working.
    Pietern also posted the following:
    https://twitter.com/v1rtu0s1ty/status/1000850141333671936?s=20
    Pietern:
    You could try mounting your dish at a 45 degree CCW rotation. This will match the vertical polarity of the signal and give you a better signal
    At least, it will better match it, I think in california you need about 30 deg CCW, so if your mount allows it, then that's great, otherwise 45 is fine too
    My permanent setup for GOES-16 in the SF bay area has this rotation as well
    Folks on the east coast don't need the rotation
    This also seems relevant: https://www.reddit.com/r/RTLSDR/comments/8j23e0/pointing_dish_to_goes16_satellite/
  • Name can't be blank
    joshua.vader • 09/22/2018 at 02:10 • 0 comments
    Per: https://www.reddit.com/r/RTLSDR/comments/9ahdzc/modification_of_wifi_grid_antenna_to_make_it_work/
    A 2.5cm spacer is required.  I have 4mm nylon spacers on hand.  After drilling the spacers out to slider over a 8-32 nylon screw, physically works to offset the secondary reflector.  I have not yet tested
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
Taking LED light painting to new heights
Project Owner Contributor
Skywriting
jeremy-weatherfordJeremy Weatherford
For when you don't need a big Fast Fourier Transform (FFT) or are just to lazy to do FFT.
Goertzel Algorithm
agpcooperagp.cooper
The 2017 Hackaday Prize
let's find people in needs and rescue them or find sounding-rockets and recover them. fastly, savely high or low and mobile!
Mobile Search and Rescue Experiments (MoSAReX)
hornighornig
Attempts to reverse engineer the latest Muse model for Neuro Feedback and BCI
Muse EEG hacking
andreasklostermannandreasklostermann
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "RTL-SDR to acquire data from GOES-16 satellite", please tell us the reason.
Send message
Remove Member
