This is actually a mash-up of two other projects, one working and one not quite. I wrote an ESP8266 8008 emulator that communicates via RS-232 and wirelessly at:
https://hackaday.io/project/28227-esp8266-based-i8008-emulator
I have another project,an ESP8266 based PCXT emulator that isn't quite working and might not ever work due to lack of RAM (and probably skill), started by "MCUHACKER01". So, I took the video guts out of the PCXT project, hooked it up to the 8008 emulator and stripped out unneeded RS-232, FTP, OTA, and wireless functions from my emulator. I then hooked up an ASCII keyboard Arduino keyboard library function (slightly modified for the ESP8266 and this project) and wrote a very simple terminal emulator for the keyboard and NTSC video with limited cursor control functions. A menu system hooks it all together.
This is a completely useless exercise, but it is technically fairly interesting. I've been doing hardware/software hacking for..."a long time" (long enough so that I can remember when the 8008 and 8080 were new and revolutionary)... and I just can't believe that this can now be done with basically a single package.
Ive added the schematic to the files in addition to the code, which is in a .zip file. As you can see, it's really incredibly simple to build.
I've also added an image from another one of my projects, a scratchbuilt paper tape reader. at:
https://hackaday.io/project/162182-punched-tape-reader-peripheral-for-8008-emulator
The smaller one of the two readers that I built I added to this project, but haven't updated the schematic. An image is in the gallery of this project with the paper tape reader added to it.
Chad Lawson
Jon Thomasson
andrew
Good old school!
