Finished the next check-out program and the ALU is working. It isn't an extensive checkout - just enough to make sure my control logic is good. I also put together a quick clock program on my Arduino to toggle the clock at about half a second. So the lights changed slowly enough for me to verify the outputs were good. I also checked the branch-if-equal-to-zero command. I have to admit I kinda like writing machine-code. At least for small test programs. Next up will probably be writing and reading the RAM. There's several different ways to access the memory and I did a lot of modifications to the MAU. I wouldn't be surprised if there are problems here.
// Program to test ADD, SUB, AND, OR, XOR functions of ALU
byteProgram(0x0000, 0x000F); // ld (0b1111, AC) // value to load into blinkenlights LEDs |****|
byteProgram(0x0001, 0x1800); // ld (0x00, OUT) // Prepare XOUT update, hSync goes down, RGB to black
byteProgram(0x0002, 0x1840); // ld (0b01000000, OUT) // hSync goes up (bit 6), updating XOUT and blinkenlights
// top of loop:
byteProgram(0x0003, 0xF00A); // beq (0x0A) // branch if equal to zero to exit loop
byteProgram(0x0004, 0x0200); // nop // nop for pipelining simplification
byteProgram(0x0005, 0xA001); // sub (0x01, AC) // sub 1 from AC register
byteProgram(0x0006, 0x1800); // ld (0x00, OUT) // Prepare XOUT update, hSync goes down, RGB to black
byteProgram(0x0007, 0x1840); // ld (0b01000000, OUT) // hSync goes up (bit 6), updating XOUT and blinkenlights
byteProgram(0x0008, 0xFC03); // bra (0x03) // unconditional branch back to top of loop
byteProgram(0x0009, 0x0200); // nop // nop for pipelining simplification
// exit loop:
byteProgram(0x000A, 0x4005); // or (0x05, AC) // test OR function (expect 0x05 result) |*0*0|
byteProgram(0x000B, 0x1800); // ld (0x00, OUT) // Prepare XOUT update, hSync goes down, RGB to black
byteProgram(0x000C, 0x1840); // ld (0b01000000, OUT) // hSync goes up (bit 6), updating XOUT and blinkenlights
byteProgram(0x000D, 0x600F); // xor (0x0F, AC) // test XOR function (expect 0x0A result) |0*0*|
byteProgram(0x000E, 0x1800); // ld (0x00, OUT) // Prepare XOUT update, hSync goes down, RGB to black
byteProgram(0x000F, 0x1840); // ld (0b01000000, OUT) // hSync goes up (bit 6), updating XOUT and blinkenlights
byteProgram(0x0010, 0x200C); // and (0x0C, AC) // test AND function (expect 0x08 result) |000*|
byteProgram(0x0011, 0x1800); // ld (0x00, OUT) // Prepare XOUT update, hSync goes down, RGB to black
byteProgram(0x0012, 0x1840); // ld (0b01000000, OUT) // hSync goes up (bit 6), updating XOUT and blinkenlights
byteProgram(0x0013, 0x8001); // add (0x01, AC) // test ADD function (expect 0x09 result) |*00*|
byteProgram(0x0014, 0x1800); // ld (0x00, OUT) // Prepare XOUT update, hSync goes down, RGB to black
byteProgram(0x0015, 0x1840); // ld (0b01000000, OUT) // hSync goes up (bit 6), updating XOUT and blinkenlights
byteProgram(0x0016, 0x80FD); // add (0xFD, AC) // test ADD function (expect 0x06 result, should rollover) |0**0|
byteProgram(0x0017, 0x1800); // ld (0x00, OUT) // Prepare XOUT update, hSync goes down, RGB to black
byteProgram(0x0018, 0x1840); // ld (0b01000000, OUT) // hSync goes up (bit 6), updating XOUT and blinkenlights
byteProgram(0x0019, 0xFC00); // bra (0x00) // unconditional branch back to 0
byteProgram(0x001A, 0x0200); // nop // nop for pipelining simplification
