The program reads an ASCII character string array.
The ASCII is tested for being in the range of 0x20 to 0x7F. Any character not a Morse code character will be flagged as a no code and will be skipped.
The ASCII is used as a pointer to the data byte that holds the Morse code.
The Morse code is then output to the relay for a dit and a dah, but the PWM outputs have a dit output and another a dah output.
I managed to use one byte of data to contain 1 to 6 bits of Morse code, and a 3 bit register to contain the number of bits of Morse code contained in this byte.
I am still working on the final mix of output activity for the final performance but I am leaning toward a relay, with possibly one or more piezo sound devices.
