WATER LEAKAGE DETECTOR AND ENERGY GENERATOR
PROBLEM IDENTIFIED: Water scarcity and scarcity of electricity in India SOLUTION:A method the prevent Leakage and Energy Generator
0 followers
As we know that the water is transported through the pipeline in INDIA and if there is a minor breakage in the pipe the leakage get start which is next to impossible to detect the leakage and repair it almost every part of India water is transported through the Pipelines.According to the survey 30%-40% water is waste because of water transportation. So,we came up with solution regarding this Problem .We have placed a self designed dynamos at different distances of the water pipe as the water will strikes the blades of dynamo it will move the voltmeter will show some reading .Now dimension of water is uniform the density and speed factor remain unchanged.So as water move forward it will strike with one another dynamo and some reading will be shown in the voltmeter.If there will be any leakage the reading of the two voltmeter will differ each other .Through micro controller we have connected our system wireless
niuyingxian wrote 08/14/2020 at 22:22 point
Hello, how is your plan implemented? I am also very interested
